Robotics Deployment application is not found -OSD.exe
I am getting an exception while executing an automation or build a solution. This is happening across all the solutions under the studio. I tried to clean up the solution but it didn't work. Here are the exception details that i am getting while running the automation from studio. I like to avoid re-installation; any help on this issue will be greatly appreciated.
Error in Studio -
Severity Code Description Project File Line
Error Deployment application is not found: C:\Program Files (x86)\OpenSpan\OpenSpan Studio for Microsoft Visual Studio 2015\OSD.exe VehicleEntry C:\xx\xx\xx\Pega Robotics Studio\Projects\AutoValueEstimator\VehicleEntry\VehicleEntry.osproj 1041
Error The "ProjectDeployment" task failed unexpectedly.
System.InvalidOperationException: Cannot start process because a file name has not been provided.
at System.Diagnostics.Process.Start()
at Microsoft.Build.Utilities.ToolTask.ExecuteTool(String pathToTool, String responseFileCommands, String commandLineCommands)
at Microsoft.Build.Utilities.ToolTask.Execute()
at OpenSpan.Build.Tasks.ProjectDeployment.Execute()
at Microsoft.Build.BackEnd.TaskExecutionHost.Microsoft.Build.BackEnd.ITaskExecutionHost.Execute()
Show More
Error in Studio -
at Microsoft.Build.BackEnd.TaskBuilder.<ExecuteInstantiatedTask>d__26.MoveNext() VehicleEntry C:\xx\xx\xx\Pega Robotics Studio\Projects\AutoValueEstimator\VehicleEntry\VehicleEntry.osproj 1041
Exception From Log File
Diagnostic Info:
Diagnostic.MachineName: XXX-XXX
Diagnostic.FullName: OpenSpan, Version= Proprietary information hidden, Culture=neutral, PublicKeyToken=XX
Diagnostic.AppDomainName: DefaultDomain
Diagnostic.WindowsIdentity: DESKTOP-xxx\dnilu
Diagnostic.ApplicationName: OpenSpan.Studio.Shell
Exception Information
1) Exception Information
Exception Type: System.IO.FileNotFoundException
Message: "Could not load file or assembly 'OSD, Version= Proprietary information hidden, Culture=neutral, PublicKeyToken=xxx' or one of its dependencies. The system cannot find the file specified."
FileName: "OSD, Version= Proprietary information hidden, Culture=neutral, PublicKeyToken=xx"
FusionLog: "WRN: Assembly binding logging is turned OFF.
To enable assembly bind failure logging, set the registry value [HKLM\Software\Microsoft\Fusion!EnableLog] (DWORD) to 1.
Note: There is some performance penalty associated with assembly bind failure logging.
To turn this feature off, remove the registry value [HKLM\Software\Microsoft\Fusion!EnableLog].
Data: IDictionary (System.Collections.ListDictionaryInternal) with 0 items
TargetSite: System.Collections.Generic.IList`1[System.String] GetAllBuildReferences(System.String, System.String)
HelpLink: NULL
Source: "OpenSpan.Build.Tasks"
HResult: -2147024894
Show Less
