StaidLogic LLC
Last activity: 21 Feb 2019 1:26 EST
Move a files from one folder to another folder
My requirements is how to move the file from one folder to another folder?
Niharika
RPA/RDA Practitioner
Another alternative way is to add the System.IO.File.Move component to the toolbox.
Right click on the toolbox and select 'Choose Items...'
Choose > Pega Robotics Static Members tab, From Global Assembly Cache radio, mscorlib,Version= Proprietary information hidden from the Assembly dropdown, Expand File, and check Move> then click OK
Drag File.Move from the toolbox.
See image for example
With release 8.0.1078 and higher you can add the 'fileUtils' component from the toolbox and use the 'MoveFile' method from Object Explorer.
See image example
Also see fileUtils mentioned in post here: https://collaborate.pega.com/discussion/ask-expert-robotics-jeff-badger-and-thomas-sasnett
StaidLogic LLC
Move file is not working is there any other way to move the folder ?(file Utils)
As the flow is going false condition.
Please find the screen shot attached.
StaidLogic LLC
Thank You!!!
Infosys
StaidLogic LLC
Thank You!
Bhargav Pokala
