CNO
Last activity: 3 Nov 2019 21:04 EST
Busyindicator
Is it possible to update the pega infinity busy indicator?
Are you going to modify Pega busy indicator image? If yes, below link will help you.
https://community.pega.com/support/support-articles/change-default-pega-busy-indicator-image
CNO
I am trying to update the attached pega infinity busy indicator. I am not able to find the exact gif file.
I tried to find this, but I could only figure out that it is an SVG file.
CNO
Hi Rachit,
Whats the SVG file name?
As Suman said this is a pure animation, there is no binary file for this. But I could see that this is used in two places.
1) Web-login(The login page)
2)pyForgotPassword(Forgot Password page)
But, these rules are available so if you want, you can modify it.
This new infinity busy indicator is pure css animation. There is no binary gif or svg to override afaik.
CNO
Can we confirm that it's not possible to override?
Kensho Tsuchihashi Yiming Huang Praveen Sagar Cheerla Do-Hyung Kong Yao Yao and 8 More
Areteans
It is possible!
please follow below steps:
1. Create a binary file with custom image (let it be "CustomPreloader")
Custom image:
2. Save-as the UserWorkForm in the available Application ruleset, add the below snippet in HTML Source.
<script>
pega.ui.busyIndicator.prototype.createIndicatorImage = function() {
if(this.oSpan == null)
this.initialize(this._sNode);
var oSpan = this.oSpan;
if (this._message && this._message.length > 0) oSpan.innerHTML = "<img src = 'webwb/CustomPreloader.gif' alt='loading' />" + " " + this._message ;
else oSpan.innerHTML = "<img src = 'webwb/CustomPreloader.gif' alt='loading' />";
</script>
Please find the attachment for the result i got.
Barclays
Have you found any solution for this ?
Evernorth
UserWorkForm
What is the rule type? is it a section, harness or HTML control?
It is a HTML fragment. (ruleset is pega ui engine , ruleset may differ according to the pega version.)
