Scotiabank
Last activity: 28 Feb 2019 13:00 EST
Data flow executed in an unexpected node
I have an agent scheduled at a particular node (let's label it node G), and it runs an activity that in turns executes a data flow. However, when I check from the data flow landing page, I see that the data flow ran in a different node (node C). This is a surprise to me since I was expecting the data flow to execute in the same node where the activity was triggered from. Is this expected behaviour from Pega 7.3.1? In particular, does the Dataflow-Execute method have to do its job in the same node where the activity that invoked it was ran on? Or can this method do its job in whatever node it chooses?
Alberto
This is expected behavior. Data flow batch runs (where the source is not abstract) - will always do a distributed run depending upon which nodes are designated to run data flows. In newer version this could also be controlled in more granular fashion with node type configurations.
