Use DevOps environment as Development environment/QA environment
Hello all,
All of our environments run on pega cloud. We have 3 + 1 environment. (Dev, Stage, Prod + DevOps).
Since, we do not have a dedicated QA environment, the plan is to use DevOps environment for QA purpose. I looked at the environment and it looks very similar to any pega environement. Are there any configuration level changes that needed to be done before importing the rap files from dev?
p.s: The import doesn't seem to work. I tried importing rap that has about 1800 rules. Import was succesful with only one rule being imported. Nothing helpful in the logs
Appreciate the help. Thanks all.
Can you enable these loggers and see the error in logs?
com.pega.pegarules.deploy.external.util.ImportUtility
com.pega.pegarules.deploy.internal.util.ImportImpl
com.pega.pegarules.deploy.internal.inventory.SynchronizerImpl
Set the logging level to ALL.
You should be able to find out the error.
Thank You
