Logs in Openspan
By default the logs are stored in %appdata%>openspan. But my requirement is I want my logs to stored into my project folder i.e., documents>PegaRoboticStudio>Projects>(my project file). How can we do this?
Thanks & Regards,
Anu
You can edit fileName value of log publisher in Diagnostics section of RuntimeConfig.xml. It accepts full paths.
Here is an example - it puts Runtime logs under c:\test\
