Stella
Last activity: 22 Jan 2019 20:16 EST
Conditional Steps
It used to be that you could conditionally run a step in case designer by specifying a when rule. It looks like in Pega 8.1 specifying a when rule to conditionally run a step is no longer supported. Is this true? What's the alternative? Orchestrate the step flow to end under a certain condition? This means that the step flow will show it as executed on the chevrons though won't it?
