com.pega.jmx.ui.util.JMXClientException: No MBeans found for the node
While trying to add nodes in SMA,always encountering this issue for node 2.
1 Weblogic is hosting 2 PRPC Application war files.
Can you provide the configuration screenshot of the Node configuration in SMA?
Does the SMA runs on the same server that host Pega?
Regards
Simon
Yes,SMA is running on the same server that is hosting Pega.
So there is a loadbalancer on top of this architecture and whenever I am logged onto node1-> SMA issue is for Node 2 and similarly when I am logged onto node 2,SMA issue is for Node 1.
So I assume you have 2 Managed Servers in the WebLogic domain. If you take away to NodeID field, does the issue still occur?
Regards
Simon
If my assumption is correct, then one of the Node should be configured as Remove JVM option, but your screenshots shows both boths have been configured as Local JVM.
Simon
