Citibank
Last activity: 1 Feb 2019 7:41 EST
Rule and App Schema Copy
Has anybody done a Rule & App schema copy from one schema to another.
Eg:
RuleSchema1 is pointing to Region A and AppSchema 1 is pointing to Region A.
I want to setup Region B with same rules/data as Region A.
So
Can i just do a copy from RuleSchema1/AppSchema1 to RuleSchema2/AppSchema2 ? If No, can you explain why ?
OR
Do i need to do a fresh install of Pega in RuleScema2/AppSchema2 ?
Hi
This approach should work. You should have the database connection properly set so that the server points to the right dead.
