Ernst&Young
SV
Last activity: 10 Jan 2019 2:26 EST
PDF created with incorrect format
Right now, I'm working on a requirement that states the generation of a PDF file with the information hold in a section and attach it to the work object, at this point I was able to do it using the OOTB activity pxCreatePDF but the file shows the controls of the section arranged in a vertical disposition, even thought its layout is inline triple and the file is not visually friendly to the user.
Then, I want to know if there is a way to generate the PDF file, showing the controls and elements of the section, as the user see them on their screen.
Attached, you will find how the pdf looks like to have a clear idea about my problem.
Thanks in advance for your help :)
