Pega 7.4 and ElasticSearch
Hi all,
Is it possible to configure Pega 7.4 with external cluster of ElasticSearch, i.e. Pega should not start embedded ES but use another ES?
Pavel
Hi all,
Pavel
Kindly check below articles. These may help you.It is worth checking these articles on elastic search.
https://community.pega.com/knowledgebase/articles/troubleshooting-elasticsearch-common-issues
As far as I understand, the second link is about Pega 8.1.
I've tried the similar configuration with Pega 7.4. There was a minor problem with ES plugins for version 2.4.0 but I've solved it by pushing search.jar with 4 plugin descriptions. And it worked more-less.
The main problem was that Pega seemed to get ES gossip nodes from DB; therefore, if all Pega nodes start with disabled search, then it cannot build indices and cannot find standalone ES. Though my configuration of Pega might be incorrect.
Pavel
