Installing Pega 7.4 in Oracle 12c
Hi!
I am trying to installing Pega 7.4 (split schema) on an Oracle 12c database. and get the below error.
Java is not installed in database.
Is there any way around this?
I thought java was required only if you wanted to use UDF:s and thus not mandatory...?
The customer is veeery leary of installing java in their database since it's shared with other application, none of which have this requirement of java.
Thanks for help!
Christer
[java] 2018-09-28 13:44:53,482 ( OracleUDFJarLoader) INFO -
[java] *****************************************************************************************************
[java]
[java] Encountered database error attempting to load UDF library onto Oracle, clean schema before running again.
[java]
[java] Exception in thread "main" java.sql.SQLException: ORA-29538: Java not installed
I found a couple of support articles. It seems that the java oracle component is still required.
https://community.pega.com/support/support-articles/prpc-715-install-fails-ora-29538-java-not-installed
https://community.pega.com/support/support-articles/receiving-oracle-err-ora-29538-java-not-installed-java
