Anthem
Last activity: 14 Dec 2018 3:39 EST
While queuing up soap service, instances are failing with database rollback error
Hi Team,
While queuing up soap service, instances are failing with database rollback error.
Found the following PDN article,but not sure if the provided hotfixes suitable for PRPC731 version.
<rowdata REPEATINGINDEX="1">Database rollback caused queue item rollback: java.lang.Throwable
at com.pega.pegarules.priv.util.StackTrace.getStackTrace(StackTrace.java:47)
at com.pega.pegarules.session.internal.async.agent.QueueManagerImpl.rollback(QueueManagerImpl.java:1174)
at com.pega.pegarules.session.internal.async.agent.QueueManagerImpl.rollback(QueueManagerImpl.java:1143)
at com.pega.pegarules.session.internal.async.agent.QueueManagerImpl.rollback(QueueManagerImpl.java:1136)
at com.pega.pegarules.session.internal.engineinterface.service.RequestProcessorImpl.processQueue(RequestProcessorImpl.java:707)
at com.pegarules.generated.activity.ra_action_processqueue_90bab9d8d8f981f8da8c556128761aab.step1_circum0(ra_action_processqueue_90bab9d8d8f981f8da8c556128761aab.java:161)
Hi Team,
at com.pegarules.generated.activity.ra_action_processqueue_90bab9d8d8f981f8da8c556128761aab.perform(ra_action_processqueue_90bab9d8d8f981f8da8c556128761aab.java:70)
at com.pega.pegarules.session.internal.mgmt.Executable.doActivity(Executable.java:3597)
at com.pega.pegarules.session.internal.async.agent.QueueProcessor.runActivity(QueueProcessor.java:786)
at com.pega.pegarules.session.internal.async.agent.QueueProcessor.execute(QueueProcessor.java:655)
at com.pega.pegarules.session.internal.async.BatchRequestorTask.run(BatchRequestorTask.java:1055)
at com.pega.pegarules.session.internal.PRSessionProviderImpl.performTargetActionWithLock(PRSessionProviderImpl.java:1327)
at com.pega.pegarules.session.internal.PRSessionProviderImpl.doWithRequestorLocked(PRSessionProviderImpl.java:1075)
at com.pega.pegarules.session.internal.PRSessionProviderImpl.doWithRequestorLocked(PRSessionProviderImpl.java:957)
at com.pega.pegarules.session.internal.async.BatchRequestorTask.run(BatchRequestorTask.java:761)
at com.pega.jsr166backport.java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:991)
at com.pega.jsr166backport.java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:532)
at java.lang.Thread.run(Unknown Source)
