ING Bank NV
Last activity: 3 Feb 2019 23:30 EST
username and password invalid for pega url hosted using virtualbox
I have downloaded pega virtual box setup which has version PEGA 8.1.1 .Everything is working fine but username and password to login pega application is not working.I tried [email protected] as username and install as password.I tried all combination like [email protected] and its not working.
Does the username and password has been changed? So please let me know how I can use.
***Edited by Moderator Marissa to move from Pega Support Community to Pega Academy***
ING Bank NV
Just want to inform its the virtualbox image which is given for new training .
ING Bank NV
Click http:// Proprietary information hidden:9080/prweb/PRServlet to access the Pega 7 application.
Course exercise login information:
- Refer to login credentials provided in the Scenario of each exercise
Administrator login information:
- User Name: [email protected]
- Password: Password123#
I tried this as well
TCS
I do have the same issue for a week now!
ING Bank NV
https://collaborate.pega.com/question/unable-login-admin-account
https://collaborate.pega.com/question/pega-74-installed-administratorpegacom-not-working
I have used all password combination mentioned in these links.Please help.
BnpParibas
Hi Rahul, Plz let know if we can download any older VM.... as I do have same issue with this vm
Amtex
Same issue here also..
VMImage link/URL suggests to use below login but it doesnt work.
I am using VMImage for 8.1 training.....
Any help here?
Commonwealth Bank of Australia
I had the same problem also with the Administrator credentials not working for the training environment.
It's not quite clear why you need access to the Administrator credential since credentials are provided as part of the System Architect Essentials v8 courses as part of the exercises, and should get you you into the Pega environment.
Amtex
Yup realized later....admin credentials might be for the people who installed and created the whole setup...
will work with userid/pwd in exercise guide.
thanks
ING Bank NV
The logins for the V8 are usually something like author_cm@gogoroad or author_ie@gogoroad and the password rules. The login ID changes with each exercise. You can jump to each exercise to see the login. If there's a master/administrator login I haven't come across it yet.
Areteans Tech
NZ
Thanks rahul it works
