JP
Last activity: 2 Jan 2019 16:10 EST
OOTB @DownloadFile API should not have an administrator privilege, should it?
I am using an out-of-the-box activity "pxConvertResultsToCSV" in order for user to download a CSV file from a page list on a section. When I test it from Designer Studio with administrator access role, it works, but when I test it from end user portal with limited access role (WorkMgr4) I get a below error.
And I know why; this is because the child activity that gets called, "@baseclass.DownloadFile" has a privilege "zipMoveExport". This out-of-the-box privilege is held only by administrator access role such as SysAdm4, ProArch4, etc. DownloadFile activity is a FINAL and hence, it is not possible to override to get rid of this privilege.
If I do Save As the entire DownloadFile activity and get rid of this privilege, it should work, but this is a very ugly solution. And the parent activity "pxConvertResultsToCSV" has to be also Saved As. Isn't this supposed to be almost a product defect because setting such strict administrator privilege for such generic API is I think too much? => Question #1
Anyways, I need to get this to work - another solution is to give this "zipMoveExport" privilege for end user's access role. Since I am using role dependencies (which was introduced in Pega 7.4), I do not want to clone the entire AROs. So I am adding only @baseclass class ARO with "zipMoveExport" as below screenshot, but is this a right approach? => Question #2
Your feedback is appreciated.
