Veteran Careers First
Last activity: 21 Nov 2018 15:50 EST
Function/expression
I am attempting to write an expression/function using expression builder in a when rule to evaluate to true only if number is integer or decimal. Or Non Alpha.
Example:
@isNumber(.property)
I tried this and it appears to work great.
try {
new BigDecimal(input);
} catch (NumberFormatException e) {
return false;
return true;
TechMahindra
Hi HenryA80,
Create a simple new function to achieve this.
FunctionName: IsNumericOnly
Parameters: input as String
Return output: boolean
Function Code:
java.util.regex.Pattern p = java.util.regex.Pattern.compile("^[0-9]\d*(\.\d+)?$");
java.util.regex.Matcher m = p.matcher(input);
return m.matches();
Function are difficult for me.
Would you be so kind to provide screenshots.
TechMahindra
Please follow following steps.
TechMahindra
PFA screenshots to create function.
Thanks.
I guess I also need to create a Library rule.
I created Library and Function.
But I do not see it in the expression builder.
Is there another step....
Vsasikumar,
It is working great but does not allow negative numbers.
How can we make this adjustment.
You can just change the expression from "^[0-9]\d*(\.\d+)?$" to "^[+-0-9]\d*(\.\d+)?$"
Let us know if this helps :)
ok
I will try that.
Thanks!
I am still having trouble.
Attached are my new results.
try {
return false;
return true;
EvonSys India Pvt Ltd
Just try property type as an integer and tried the given function @IsInteger and it's for your requirement
Property Type is currently decimal.I can't change the property to integer because it needs to accept decimals.
@IsInteger does not allow decimals
Create a function and try with a regular expression which they discussed as above members
