Common Wealth Bank
Last activity: 14 Nov 2018 15:46 EST
log file path change not working as expected
I am trying to change the location of the pega log files by appending different log file location to save i,e${jboss.server.log.dir} insetead of "${sys:pega.logdir} , but in run time the relative path for "${jboss.server.log.dir}" is not fetching
<RollingRandomAccessFile name="PEGA" fileName="${sys:pega.logdir}/PegaRULES.log" filePattern="${jboss.server.log.dir}/PegaRULES-%d{MM-dd-yyyy}-%i.log.gz">
I noticed a new directory got created with name ${jboss.server.log.dir} and files are saving into that. Please suggest how to save the log file to jboss server log directory instead of pega temp directory.
we are using Pega 7.4 version.
Have you checked that you added your path to a jvm arguement e.g -Djboss.server.log.dir=<path>
Also I believe the appender should look something like below you need sys: to resolve variables.
<RollingRandomAccessFile name="PEGA" fileName="${sys:jboss.server.log.dir}/PegaRULES.log" filePattern="${sys:jboss.server.log.dir}/PegaRULES-%d{MM-dd-yyyy}-%i.log.gz">
