[email protected]
Posted: Dec 14, 2015
Last activity: Jan 19, 2016
Last activity: 19 Jan 2016 13:20 EST
log files are not going to the specified path
Hi
i have specified defined location for the logs in prlogging.xml but since last few days they are moving to temp folder.
Anyone have any idea about this.
i have checked the prlogging.xml file but the path defined is not temp directory.
What should i do..?
There are other ways to set path for log file as well.
At runtime check your JVM parameters, make sure you are not setting log file directory in the command line parameter
