Gettig error while opening personal edition url-
After installing personal edition tried opening below url:
and getting below error:
HI ,
Could you please tell me which server you are using and confirm the following :
1. Your server is up and running. ( Type http://localhost:8080 and verify )
2. Your "prweb" is successfully deployed and has started (You can check this in manager portal of server).
Do you see any errors in Pega / Server logs during start-up?
