Pega is not working under docker container
Pega application is not working under docker container, after configuring the server.xml file placed the prweb.war and prsysmgmt.war under apps directory and started the application JVMs, however its not expanding the war files, can you anyone assist on the same?
Thanks!
It's impossible to answer without knowing how you have configured your docker environment.
In a first step, I'd suggest going through the tutorial here https://collaborate.pega.com/community-post-unpublished-or-under-review , run it successfully and then adjust your environment or build on top of the one built with the tutorial.
