Warning - SQLJ schema
Hello
We have a lot of warning when creating a SQLJ schema
CREATE SCHEMA
GRANT
psql:/apps/sources/pljava-REL1_5_STABLE/src/sql/install.sql:15: WARNING: java.lang.NoClassDefFoundError: org/postgresql/pljava/internal/Backend
psql:/apps/sources/pljava-REL1_5_STABLE/src/sql/install.sql:15: WARNING: Unable to load class org/postgresql/pljava/internal/Backend using CLASSPATH '-Djava.class.path=/opt/rh/rh-postgresql96/root/usr/share/pgsql/pljava/pljava.jar'
psql:/apps/sources/pljava-REL1_5_STABLE/src/sql/install.sql:15: WARNING: failed to load initial PL/Java classes
HINT: The most common reason is that "pljava.classpath" needs to be set, naming the proper "pljava.jar" file.
Environment Details
OS => RedHat 7.4
Database => Postgresql 9.6
Application Server => Apache Tomcat 8.5
Media => Pega Platform 7.4
Java => JDK 1.8.0_152
