Accenture
Last activity: 31 Oct 2018 5:15 EDT
Spacer in Auto Prepend for an auto complete control
I have an auto complete displaying username and userid . My requirement is while displaying username it should be formatted as (Name:<space><username>). I am able to display as (Name:<username>) by using the Auto Prepend and Auto Append options available in UI properties.
Can you let me know how to display space after colon?
Please find attached screen showing the configuration i did to display in the format needed without space.
FR
Have you tried something like
Accenture
Yes i tried
1.
2. <style> </style>
3. /t
4. <br>
many more html tags like above. but whatever i give there it is displaying as is in output..
Udhayachander Gopalaswamy
Accenture
Any thoughts please?
Hi ,
I tired an able to get the desired output.
Attaching the screen shot of the result and configuration. Let me know still you are facing this behaviour.
Accenture
Let me explain what i am looking for with the example from your screenshot. In your screenshot auto1.png, display is
(Name:<some ABC>:
My requirement is, i should be able to display as below:
You see the difference? there should be a space after Name: and before <some ABC> value.
We usually use <html> tags like  , </t> etc to display the space. So, how can i give such html tags in "AutoPrepend" field?
Hope i am clear!!! Request your support.
Accenture
Is it possible to do? Anyone has any ideas?
If you are using a report definition to retrieve the values for you dropdown, you could use a function alias to prepend the space to the name values returned by the report. I believe a function alias to do that already exists, and if not, it would be pretty simple to write.
Manisha Mahapatro
Accenture
Hi Lee,
I am using a RD but even there it is the format i have to give as in UI level on the gear icon. Auto append and Auto prepend options are the only one i have in both the scenarios.
Please find the screenshot attached. I highlighted in yellow where i am looking for a space display. I tried with but my output shows with text display.
