StaidLogic LLC
Last activity: 24 Oct 2018 6:53 EDT
Does openspan support office 2016 Home & Student edition
I am using PegaOpenspan studio (productVersion="8.0-999.0") and excel 2016 (Home & Student Edition)
Whenever I try to work on excel I am getting an error saying that Microsoft Office 2016 is not present.
Even I tried to add dll from Office 2016 folder and performed steps from help topics but it won''t works
![](https://accounts.pega.com/sites/default/files/styles/user_image/public/1689973000/3a78fee4-a7e7-4a05-b0f7-356e3689e691.png?itok=nN1zP2KU)
8.0-999.0 isn't actually a valid version. Check your version by opening Studio and going to Help >> About Pega Robotics Studio.
You will need to have selected Office 2016 during install of Pega Robotics. You can verify that you have the correct version selected by going to your %appdata%/openspan folder and checking the RuntimeConfig (and StudioConfig) for the OfficeVersion key. It should look like this:
- <add key="OfficeVersion" value="2016" />
If this is correct, reset your toolbox and add the connectors back in (if they don't do it by default). Then add your connector to the project and try again.
StaidLogic LLC
My installed studio details are as follows
Pega Robotics Studio Version 14.0.25420.1 D14REL
Microsoft .NET Framework Version 4.7.03056
Installed Version: Express
Pega Robotics Studio 8.0.1089.0
I had tried steps as you explained in post but still not works for me.
Can you capture and attach a RuntimeLog?
Attached steps on enabling logs. Recreate the issue with logs enabled and upload them here.
StaidLogic LLC
Hello
Kindly find attached logs.
Great. Thank you. Ok, the error is occurring because we do not detect the registry values that you would normally find with Office installations. We're looking for the office value here : ...SOFTWARE\Microsoft\Office\2016.
Can you check? Or additionally find where the office registry value is set?
StaidLogic LLC
Kindly find attached screenshot of registry
Mariane Ammar
StaidLogic LLC
Hello
Required screens are attached in reply troll.
Kindly take look in issue. Since there is urgency.
Osanda Gunawardena PRADEEP CHOWDARY PYDI
