Maantic Inc
Last activity: 25 Jan 2019 3:16 EST
Property not picking on local actions with a When condition
Hello All,
I have checkbox that has the following Actionset:
1) Post Value
2) Run Data Transform
3) Refresh Section
4) Local Action (based on a when condition to check whether pagelist is > 1
My data transform appends data to a top level page which are copied based on certain criteria. I want my local to fire only when the pagelist is > 1. I have tried following approached:
1) A when rule in the in local action to check the lengthofpagelist which does not work
2) Setting a flag value in my data transform and having the value displayed on the UI and again firing the Local Action based on value.
The first time I check the box, nothing happens however when I check and uncheck the box again the local action displays'. However, when I click cancel, the popup open up again.
I am all out of ideas. It would be great if someone could help!
Sanjay
***Updated by moderator: Lochan to update platform capability***
Could you please provide snapshots of your datatransform.
