Build a Multi-Step Function in a Report Definition
We are trying to build a report definition to calculate some values to return and be available to another application referencing ours. The issue I am encountering is that I need to take multiple properties to come up with a "sum" to display in the report. I've listed the equation that I would like to create in the report definition, but have not found a way to produce the desired result.
Any help would be appreciated.
((.PLATTSValue/3.78541)/.ExchangeRate)+.BuyDifferential+.FuelLevies+.MarginValue)
All of the listed properties are part of the report definition already.
Jeremy
Can you try the same using Embed-Userfunction ?
