The difference between PegaRULES:User1 and PegaRULES:User4
| PegaRULES:User1 | Application user with limited capabilities. Cannot perform assignments on worklists other than user's own worklist. Uses the Get Most Urgent to obtain the assignments to work on next. |
| PegaRULES:User4 | For users with broader capabilities. Can open any work object in the application. Can perform assignments only on own worklists. |
Above is from Pega Help but to me both sounds to me you can perform assignment as long as it is assigned to himself. I know you need to have WorkMgr4 to perform other assignments. What exactly is the difference between User1 and User4?
[User4]
Looking into their ROLES, you can see obvious differences such PegaSocial Access:
