Siemens Technology and Services Private Limited
Last activity: 30 Nov 2018 13:28 EST
'Set Style' action does not work.
We have a requirement to change the color of text in a text box 'on change'. For this I tried:
'On Change' --> 'Set Style' on the Actions tab of the text box control. But this just doesn't work. The platform version is 7.2.2
Is this a product issue or am I missing something? Can anyone advise please?
Upon reviewing the associated Support Request, SA-67211 Set Style action does not work in the On Change event was generated as the resolution. Please refer to this SA if you're having the same difficulty.
FR
Can you check if the SetStyle on the UI gallery is working for you and compare with your configuration maybe:
4th Source
MX
I have the same issue, apparently it works only in Focus action, but if you want to apply a new style on Change action it is not working. I have tried to research if the Skin is overriding the new style but I did not find anything.
Paul Tang King Yu Tam Richard Spellman
I am able to reproduce the issue in-house. Also checked in UI Gallery, and could again reproduce the issue. Only Focus seems to be working. This looks like a bug.
Since this was determined as a bug, please continue investigation with Pega GCS via an SR. Please let us know the SR# once created.
Amdocs
MX
SR created SR-C66086
Thank you! I have linked the SR and this post for effective troubleshooting.
