NewMail event not firing
Team,
Issue with NewEmail event, only with breakpoint in place, the event is firing otherwise not.
Please see the below automation flow:-
Team,
How would you know that it is not firing? In your automation you are simply starting an interaction. Nothing you are doing produces anything that you could "see". Trigger something that you can detect like a MessageBox or write something to a UI to tell you if it is happening.
