Robotics 8.0 jQuery onchange event handler not react on the change event fired by "RaiseEvent" method
I wanted to automate a web application that has many controls on the web page that are hooked up with onchange event handler using jQuery.
I have tried to mimic onchange event by calling "RaiseEvent" method in my automation, but without success.
For trouble shooting purpose I created a simple HTML (see attached jquery-test.txt), and there are two findings.
1. onchange event handler directly specified on the html input tag does work.
2. onchange event fires two times in a single "RaiseEvent" method call.
To determine if this duplicated onchange event, the culprit that caused jQuery event handler stops working,
I wanted to know if there is a way to limit the "RaiseEvent" method call fires event only one time?
Chunzhi
