IT Solution Service
SG
Last activity: 27 Aug 2018 9:18 EDT
Version dropdown in Class rule form is throwing an error
I have just installed Pega 7.4 and created an application. When I use down arrow in "Created in version" field drop down in class form, system gives an error as below. I have never seen this issue in the past, but does anyone know why?
I am trying to paste PegaRULES log file but actually every time I use down arrow key system seems to hang and not really ERROR log is seen.
Vodafone
Hello Cloe,
Thanks for posting your query on PSC :)
This is the known issue in Pega 7.4, You should find the special character in the network call. Request to create SR and request for Hfix-45486.
Please find the below article: https://community1.pega.com/support-articles/created-version-not-populated-class-ruleform
Naveen
FR
Can you try to trace this action to check what is going wrong
Vodafone
Hello Cloe,
Naveen
CollabPartnerz
Could you please share configuration details.
IT Solution Service
SG
What is configuration details?
Tata Consultancy Services
Do you have any open version availible in application ?
IT Solution Service
SG
I have obtained HFIX-45486 and just installed it. As a result, the issue is gone right away. The issue was that Pega was sending special character "[", and that was causing the issue. This issue may happen only with Tomcat but it is better to apply for other app server environment.
Hi There,
In case your client hangs, there is chance of PEGA0005 in Alert logs. Also check if LLC cache is corrupt.
Ujjwal
