Tenet Healthcare
Checking the Check Box in a Grid
Hi
I am facing an issue automation not able to check the check box in a grid which has HTML Table structure with check box at match cell and data cell. The problem is match cell also showing separate table and datacell also showing separate table. Check Box at match cell and data cell able to get control but did not find normal check box control methods like "IsChecked" extra. Datacell showing as a check box control / if I do individual select element check box getting as On element- but did not have checkbox properties or methods like IsChecked or other properties. Attached images of checkbox properties/events/methods as well HTML Table Grid /table check box image.Automation need to check the corresponding check box -based on "label"- is shown "DEA"
Any suggestion much appreciated.
