TATA Consultancy Services Ltd
Last activity: 29 Feb 2024 0:03 EST
Check Box Issue On Editable Mode In Repeating Grid Layout
We have added checkbox as a column to table layout which is referred from repeating dynamic layout and saved the section.
While running the case we have landed on the same screen with checkbox as a column in table layout.
We have buttons on the bottom of screen namely saveandclose whch should save and close work item.
We haven't performed any click on checkbox, but just clicked save and close.
save should happen and case has to be closed on click of save and close.
But on click of save and close, the Outcome we are getting (after adding checkbox as a column on table layout without performing any action on it) - The operation completed successfully but returned no content.
Can anyone please help us on this, or anyone faced this issue before.
@VivekT6256
If the UI is sourced from a D page, check if the data page is in read-only mode. In that case change it to Editable mode and try.
In case you want to enable reload per interaction which is not available for Editable mode, use an utility to remove the data page before hand (may be in preactivity in flow action or in a defer load activity before the UI loads) so that when again it is accessed, it will be reloaded.
