Mercedes Benz Mobility
DE
Posted: Aug 8, 2018
Last activity: Aug 20, 2018
Last activity: 20 Aug 2018 22:40 EDT
Can we create database instance, which connects to SQL server database with windows authentication?
Is there a way, from PRPC V7.1.8 to connect to MSSQL server database which uses windows authentication? Please help to clarify.
Thanks, -S Ch Avinash
You may try to create the JDBC Connection. Go to DesignerStudio, then on the left pane please navigate to the Records->SysAdmin->Database and create the new connection.
Create a DATA-ADMIN-DB-NAME instance as below. Select JDBC URL listed below
Also please take a look at the following article:
Let me know if this work for you.
Lukasz
