Legerity LLC
Last activity: 6 Aug 2018 13:39 EDT
What is the difference between Save As and Specialize by Class or Ruleset
An existing rule can be saved as or specialized by class or ruleset. What is the difference between the two features?
I noticed that saving a rule as or specializing it by class or ruleset does exactly the same thing. Save as allows you to apply it to different class and save in a different ruleset.
Thank you.
Hi Micheal,
Please find below explanation for both functionalities :
Save As : Use the Save As form to copy an existing record's functionality to a new record with unique key parts. This form is pre-populated with the original record's key parts and creates default values for the new record's context.
specialized or circumstance rule : You can create a specialized or circumstance rule to create a variant of the rule that can be triggered only conditionally. The created rule is resolved and active only when the specified conditions are met. Create specialized or circumstance rules to address dynamic business requirements without changing the core logic every time.
FYI , Please see the below links for detail explanation :
https://community.pega.com/sites/default/files/help_v74/procomhelpmain.htm#designer-studio/copying/ds-copying-a-rule-or-data-instance-tsk.htm
Hi Micheal,
https://community.pega.com/sites/default/files/help_v74/procomhelpmain.htm#designer-studio/specializing/ds-specializing-rule-tsk.htm
