ericsson
Last activity: 22 Aug 2018 15:41 EDT
Impact on application on installing TLS version 1.2
I am running pega application with pega version 7.3.1 and like to install TLS version 1.2.
Please let me know will there be impact on application on installing TLS version 1.2
***Updated by moderator: Lochan to branch reply and create new post***
I am no expert regarding SSL Ciphers and protocol, but I believe the SSL implementation should be transparent to Pega Platform. Are you specifically looking to improve encryption for browser-to-platform traffic or application-to-application (services and connectors)? Are you working with credentials that are configured in security profile referenced from connect-rest or connect-soap rules?
ericsson
Hi Werda,
Yes we are looking to improve encryption for browser-to-platform traffic or application-to-application (services and connectors).
ericsson
Please help.
specifically- you need to make sure the compatibility of SOAP/REST w.r.t TLS 1.2
CollabPartnerz
Could you please check the compatiability
ericsson
Please suggest how we can check the compatiability of SOAP and REST with TLS 1.2 version.
We are currently running TLS 1.0 version.
will there be any impact if we upgrade to TLS 1.2 ?
You can use SoapUI to test if your existing SOAP services are compatible with TLS 1.2
You can explorer https://www.getpostman.com/ for REST to make sure its compatible with TLS 1.2
Viswa Chaitanya Bellamkonda
ericsson
Thanks Arvindmalav for reply.,
I have not yet install TLS 1.2 . I would like to know before doing test that will there be any impact of installing TLS1.2 version on Pega.
ericsson
Please help. Is there any impact after installing TLS1.2 version on Pega.
ericsson
please help
Kyle MacArthur
TLS 1.2 is supported. This is not really a Pega issue. You need to test your system.
Pega supports TLS 1.2, so everything in Pega should work.
