Presentation Layer Rules
We have a certain requirement to find out the list of presentation layer rules by rule referencing. We have found the below list of rules as end point rules(presentation layer). Can anyone please validate if this list is good enough or there are more rules to be added into the list.
PYCLASS |
Type |
Rule-HTML-Harness |
UI |
Rule-HTML-Fragment |
UI |
Rule-File-Text |
UI |
Rule-HTML-Paragraph |
UI |
Rule-Map-eForm |
PYCLASS |
Type |
Rule-HTML-Harness |
UI |
UI |
Rule-File-Text |
UI |
UI |
Rule-Map-eForm |
UI |
Rule-HTML-Section |
UI |
Rule-File-eForm |
UI |
Rule-PortalSkin |
UI |
Rule-Obj-HTML |
UI |
Rule-Obj-JSP |
UI |
Rule-File-Form |
UI |
Rule-HTML-FixedList |
UI |
Rule-HTML-Property |
UI |
Rule-Gallery-DemoUnit |
UI |
Rule-Automation-Tour |
UI |
Rule-Theme |
UI |
Rule-File-Bundle |
UI |
Rule-Navigation |
UI |
Rule-Obj-List |
UI |
Rule-Portal |
UI |
Rule-Obj-XML |
UI |
Rule-File-Stencil |
UI |
Rule-Declare-Index |
Correspondence |
Rule-Connect-SQL |
Correspondence |
Rule-Query-List |
Correspondence |
Rule-Query-Summary |
Correspondence |
Rule-PegaCA-DataSource |
Correspondence |
Rule-RDB-SQL |
Correspondence |
Rule-Alias-Function |
Correspondence |
Rule-RData Base-SQL |
Correspondence |
Rule-Obj-SummaryView |
Process |
Rule-Obj-ListView |
Process |
Rule-Report-AgeColumns-PastGoal |
Process |
Rule-Report-AgeColumns-Satisfaction |
Process |
Rule-Report-AgeColumns-AllOpen |
Report |
Rule-Category |
Report |
Rule-Report-AgeColumns-Resolved |
Report |
Rule-Shortcut |
Report |
Rule-Obj-Report-Definition |
Report |
Rule-Report-RuleBase |
Report |
Rule-Report-AgeColumns-PastDeadline |
Report |
