Will requestors get killed when node is stopped
We brought down all the nodes and can see lot of cases in pr_sys_locks table on requestor.
So the question is requestor will be killed or not when you brought down the node?
I know on case lock will be released once the case lock time is reached.
Regards
Gouri Shankar K
Gouri - Yes, all the requestors will get killed when the node is take down.
Umakanth.
Hi Gouri
Yes, thats how it works. If you shutdown the node all requestors will be killed.
Regards
Bhavya
No that's not how it is working hence posted this. You can also try from your end.
Regards
Gouri Shankar K
Can you clarify a bit more what you mean by "brought down the node"? How do you do that exactly by a command line or anything else?
brought down - i mean stopped the node(JVM) through console.
Regards
Gouri Shankar K
When you make node to down all the requestors will be killed
Below link might help you.
https://collaborate.pega.com/question/requestor-count-huge-requestor-management-sma
