HSBC
Last activity: 25 Jul 2018 3:07 EDT
Flow design
Suppose I want to send flow design to client. How can I save and send big flows? Our application is based on 6.2V
Thanks in advance.
PEG
PL
Hi there,
I could see that the later version of PRPC has "Open Stored flow image" on the action tab of the flow.
I am not sure of 6.2 version. Just check once if you could see something like that on the action tab of the flow.
HSBC
Thanks for the response but unfortunately there is no such option in 6.2
CollabPartnerz
Yes.Open stored flow image is available only in 7 version.
Shrikant Pustode Bharathan T
LTI Mindtree
Hi
When we create Flow rule, then pega automatically creates its corresponding Binary rule in the "jpg" format for this flow. This binary file contains entire picture of flow in "jpg" format.
Example:
Let say, when we create "xyz" flow rule, then pega creates its binary rule as
"webwb • Ince_Fw_Hyd_WorkXYZ20180721t130212_146_gmt • jpg".
Where Ince_Fw_Hyd_Work is a Applies to class of flow rule,
XYZ is a flow name and 20180721t130212_146_gmt is time stamp
In your case, please check this binary rule created/present or not.
HSBC
Thanks for this..I have checked in binary files but I can see only one flow image out of 200+ flows. Is there any way to generate binary flow of any flow?
Suebwong Kasemsawasdi
LTI Mindtree
Hi
Can you try this.
Open your required flow rule and check-out the rule and go to private check out and find any binary rule is available here. If available then open and download "jpg" file from here. And let me know.
TCS
Yes you can use flow image which is availible in binary file.
HSBC
I have tried but couldn't find the image realted to flow. :(
TCS
Open your flow, then go to actions you will find Open stored flow image then binary file will open, so you can download that file.
still if you face any issues please revert back to me.
HSBC
Sorry but our application is based on 6.2V. So there is no such option
