CGI
Last activity: 4 Mar 2019 22:52 EST
Issue: Adding a data reference list to your data model
Using Pega 7.3
As per the url "https://community.pega.com/sites/default/files/help_v73/procomhelpmain.htm#designer%20studio/data%20designer/data-designer-dt-adding-data-reference-list-tsk.htm%3FTocPath%3DData%2520creation%2520and%2520management%7CData%2520type%2520management%7CCreating%2520a%2520data%2520model%7CAdding%2520fields%2520to%2520your%2520data%2520model%7C_____5", we can add data reference list to your data model.
I am not able see "Data reference (list)" option in Type column. Please find the screen shot below.
Guide me......
***Edited by Moderator Marissa to update platform capability tags; add DOC Bug ID***
Hello!
This is something that we may have in the future, but as of now, this is not available in any of our versions.
From your screenshot, it looks like you are attempting to add this to the Data Model tab for a Case Type. The help file you've referenced is related to the Data Model tab for Data Types. It looks like this is not available for the Data Model defined on a Case Type, but can be added to the Data Model defined on a Data Type.
Hope this helps!
-Kurt
CGI
Thanks Kurt...
The help file says about Data model for Data Type and Case Type both.
Can someone confirm that "Data reference (list)" is not available for Data Model defined on a Case Type?
CGI
Thanks in Advance...........
Nisitha Masakorala
CollabPartnerz
CGI
I have already shared the same link above chain. As per the url, Data reference (list)" is available for Data Model defined on a Case Type
Query, Can is someone confirm that "Data reference (list)" is not available for Data Model defined on a Case Type?
Best Regards
U Rajasekhar
CGI
Best Regards
U Rajasekhar
CGI
Best Regards
U Rajasekhar
CGI
Using Pega 7.3
Best Regards
U Rajasekhar
CGI
Using Pega 7.3
Best Regards
U Rajasekhar
Hi @RajasekharU0829,
I confirmed with the team here and "Data reference (list)" is only available for Data Designer.
Tata Consultancy Services
HI,
In which version we can see that?
CGI
Thanks....
In which version we can see "Data reference (list)" for Data Model defined on a Case Type?
Hello!
CGI
Thanks............
Aaseya IT Services Pvt.Ltd
IL
Hi RajaSekhar,
"Data Reference List" is a not a data type as specified. Here we have two scenarios, One is "Data Reference" and "Data Reference List", with DataReference, Pega creates a DataPage of type Page, Whereas with DataReferenceList Pega creates DataPage of type List.
Ex: When we create a Data Type "PersonalData", after creation of Local Source Pega creates two Data Pages "D_PersonalData"(for Single Record)-->DataReference and "D_PersonalDataList"(for multiple records)-->DataReferenceList.
Specifically we don't have option to select DataReference or DataReferenceList in the Data designer or Case Designer.
Brendan Horan Wolfgang Radl
