Ucare
Last activity: 13 Jul 2018 0:44 EDT
PEGA update 7.3.1 was successful but system shows 7.1.7
Hello,We updated our application from pega 7.1.7 to pega 7.3.1. The Update was successful and i restarted the server and launched the application.But application is still showing 7.1.7.
How did we fix this ?
***Edited by Moderator Marissa to update SR details***
Kavitha reported that the issue doesn't exist. It had something to do with the environment.
Swedbank AB
SE
Hello Kavitha,
Have you completed all the post-upgrade steps mentioned in the below document?
If not, kindly do so and let us know if the issue gets fixed.
Pawan
Ucare
Yep followed all the steps.But still not working
Hi Kavitha,
If you have followed Out of place upgrade with one/two DB, can you please confirm all of the below are successful without any issue:
1. Migration rules to temp DB.
2. Upgradation of migrated rules in temp DB.
3. Rule schema object generation.
4. Data only upgrade.
Venkat
Akhil Reddy Patpi
Ucare
Its Out of place upgrade.Verified the schema.Everything seems to be right.with the SR, i have attached the logs as well.
PEG
In addition to the other suggestions did you also undeploy the 7.1.7 ear/war file and redeploy the equivalent from the 7.3.1 media?
Ucare
Tried this as we had same issue in dev update.But it did not help in stage env. system got down after i replaced the war file
