- Get Help
Back to top
Back to top
Related content:
Trigger build on merge is not happening
Trigger build on merge branch - Status showing not started in Pega 7.4
Custom Repository Implementation - Trigger build after merging the branch
how to Merge Branches in Pega 7.3.1
Jenkins in Pega 7.3.1
Custom Repository in Pega 7.3.1
7.3.1 PEGA update failed with SQL exception Cannot drop the trigger 'trpr4_base
Rollback in Pega deployment Manager 7.3.1
Pega 7.3.1 DevOps Pipeline installation
Are you using the 'Publish to repository' option in the Branch Explorer?
The repository you use for publishing the branch should be a Pega repository and the Authentication Profile used should have your application.
Also, when you view the XML for the DATA-PIPELINE-CONFIGURATION instance, do you see pyStartBuildOnBranchMerge set to true?
I found a bug item in our system where editing the pipeline to change the 'Trigger build on merge' property did not update the pyStartBuildOnBranchMerge value. This has been fixed in 7.4. This would only apply if you had initially created the pipeline without the option checked.
