Best Buy Co Inc.
Last activity: 12 Jul 2018 3:08 EDT
Trigger build on merge is not happening
We have configured a simple DevOps Pipeline in our dev environment (7.3.1) and check the box for "Trigger Build on Merge" however after testing merging a branch the pipeline is not getting kicked off.
We can kick off the pipeline manually by clicking Start Build button on the pipeline landing page.
Thank you in advance
Jay
Best Buy Co Inc.
currently i see no branches listed there. however my application has one branch that i am using to test this functionality.
Best,
Jay Hysenbegasi
hi Jay,
When in merge wizard , are you seeing a dropdown with the list of pipelines?
-Mudit Sharna
Best Buy Co Inc.
No That option is not available at all once i initiate the branch merge process. am i doing the set up wrong?
you need to populate DSS called RMURL on your development system. Please refer to the documentation for more details on this DSS.
Mudit Sharma
Best Buy Co Inc.
Hi yes I have listed all the RS there. But not the branch I will try that thank you .
i confused the two settings initially. HostedRulesetsList is now listing the branch as well. and the RMURL setting was already configured correctly
AI4Process
Hi I'm also facing this issue in pega 7.3.1 platform any fixes??, I have configured RMURL and HostedRulesetsList correcty. and sharing same node for both Dev and RM.
Thank you for posting your query in the PSC. This looks like an inactive post and hence, we suggest you create a new post for your query. Click on the Write Post button here. Once created, please reply back here with the URL of the new post.
AI4Process
Hi Tharine,
Thanks for sharing the thread url.
hi Jay,
What status are you seeing under Actions->View Branches on visualization page for this pipeline?
Please also post logs from the Development system.
Mudit Sharma
