Ucare
Last activity: 9 Jul 2018 2:22 EDT
7.3.1 PEGA update failed with SQL exception Cannot drop the trigger 'trpr4_base
We are running PEGA update from 7.1.7 to 7.3.1 and on running , it failed wiht below exception.My update was successful and ran good in Dev, qa and train.But in stage env alone it failed.
a] 2018-07-05 21:45:48,067 ( SQLLoaderInternal) INFO - File: mssql00010.sql
[java] 2018-07-05 21:45:48,072 ( SQLLoaderInternal) INFO - DROP TRIGGER RULES.TRPR4_BASE
[java] 2018-07-05 21:45:48,081 ( SQLLoaderInternal) INFO - Failed to execute SQL in file mssql00010.sql
[java]
[java] com.microsoft.sqlserver.jdbc.SQLServerException: Cannot drop the trigger 'trpr4_base', because it does not exist or you do not have permission.
[java] at com.microsoft.sqlserver.jdbc.SQLServerException.makeFromDatabaseError(SQLServerException.java:217)
[java] at com.microsoft.sqlserver.jdbc.SQLServerStatement.getNextResult(SQLServerStatement.java:1635)
[java] at com.microsoft.sqlserver.jdbc.SQLServerStatement.doExecuteStatement(SQLServerStatement.java:865)
[java] at com.microsoft.sqlserver.jdbc.SQLServerStatement$StmtExecCmd.doExecute(SQLServerStatement.java:762)
[java] at com.microsoft.sqlserver.jdbc.TDSCommand.execute(IOBuffer.java:6276)
[java] at com.microsoft.sqlserver.jdbc.SQLServerConnection.executeCommand(SQLServerConnection.java:1794)
[java]
[java] at com.microsoft.sqlserver.jdbc.SQLServerStatement.executeCommand(SQLServerStatement.java:184)
[java] at com.microsoft.sqlserver.jdbc.SQLServerStatement.executeStatement(SQLServerStatement.java:159)
[java] at com.microsoft.sqlserver.jdbc.SQLServerStatement.execute(SQLServerStatement.java:735)
[java] at com.pega.pegarules.install.SQLLoaderInternal.readAndExecuteSQLStatements(SQLLoaderInternal.java:151)
[java] at com.pega.pegarules.install.SQLLoaderInternal.load(SQLLoaderInternal.java:110)
[java] at com.pega.pegarules.install.SQLLoader.loadInner(SQLLoader.java:98)
[java] at com.pega.pegarules.install.SQLLoader.load(SQLLoader.java:77)
[java] at com.pega.pegarules.install.SQLLoader.main(SQLLoader.java:65)
[java] 2018-07-05 21:45:48,102 ( SQLLoaderInternal) WARNING - Statement: drop trigger Rules.trpr4_base
[java] 2018-07-05 21:45:48,104 ( SQLLoaderInternal) WARNING -
[java] ********************************************************************************
[java]
[java] Encountered a SQL Exception, clean schema before running again.
[java]
[java] 2018-07-05 21:45:48,067 ( SQLLoaderInternal) INFO - File: mssql00010.sql
[java]
[java]
[java]
