Mphasis Unleash the Next
Last activity: 29 Dec 2018 2:35 EST
Not able to interrogate objects/controls in Windows Application.
I am working on WIndows Application. To interrogate that using Windows Adapter.The problem here is, the objects or controls not able to capturing or interrogating.When i am trying to interrogate the controls, MDI Client only interrogated(The controls, Tabs and Menu's having in the MDI screen not able to interrogating by the "BullEye").I tried from Windows tab also but there not listing the all controls(having in MDI Client) to create objects. From Windows tab and interrogation form i can able to create the obect for MDI Client(The screen which contain all controls) only.I did with Add Control Regions option, objects has created but not Matchrules created(showing green tick mark on objects in object explorer). In Runtime not identified and not set the values for that controls.
2.And one more request is,
I am trying to interrogate the controls (error message label and OK button) pop up box within same windows application. When i click anywhere on that popup with mouse that would be enabled and activate to take actions on that popup window and then we can click on that manually. When we click on somewhere other than popup window, that popup window will be disabled.
The problem is, we should click on Interrogation form and then drag and drop on control to interrogate or create object(here we are clicking other window so popup window becomes in disable mode). When i trying to interrogate controls on popup window that entire popup window not highlighted to interrogate even controls having popup window also not highlighted. I tried through Windows option also but not get results.
-->These problems have repeated for entire application.
Please give suggestions to overcome these issues.
Chinna.
***Updated by moderator: Lochan to tag SR***
