Blue Rose Tech
Last activity: 20 Jun 2018 8:03 EDT
Get Operator List and load in DropdownList
I am new to Pega Application development. I have a requirement to get list of operator name , email address show in dropdownlist. Kindly provide all steps to acquire above requirement
***Edited by Moderator Marissa to update platform capability***
Ncs Pte Ltd
SG
Create a RD in Data-Admin-Operator-ID Class. Use it as a dropdown source
Check this pzGetOperatorsForAccessGroup for reference
Dipti Aggarwal
Blue Rose Tech
Hi Rohit,
Do we need to create data page after creating RD
Hi Prakash,
Datapage could be better since it would not hit DB all the time and would save you time.
Create a Data page and source it with RD.
Ujjwal
Blue Rose Tech
Hi Ujjwal,
I have created report definition. But when i tried to datasource data page with report definition , I am not sure how to configure response data transform field which is mandatory. Can please explain how to configure response data transform.
Prakash
ben n
Hi Prakash,
Response DT is not mandatory. Please use DP type as List to get option for RD.
Mounika Bodapati
Blue Rose Tech
Hi Ujjwal,
Screen shot helped me a lot. I have configured data page as suggested. My Data page have fields like userid, username and email which I have sourced to dropdown - userid, username . On selecting username have to display corresponding email in a textbox. How do configure this?
Prakash
Amarkumar Devaki ryuta sekine Wojciech L
Ncs Pte Ltd
SG
Your wish you can use both RD or Data Page to give source for Dropdown
Blue Rose Tech
Hi Rohit,
I have managed to populate data in dropdown using Report definition. Report definition has fields like id, name and email. when i select a name in dropdown corresponding email address have to be displayed in a text box .. Help to give me solution for this.
Mastek
Hi
Trying using parameterized data page for this.
Once you select the operator, pass that as the parameter to a datapage to and get the email id.
Regards
Bhavya
Blue Rose Tech
Hi Bhavya,
I am new to pega. Can please provide some sample screenshots or code step by step
Prakash
Aaseya IT Services Pvt Ltd
SA
In that case better to use Autocomplete tab and follow the attached screenshot.
You can get the email in one property and use that property to display the email same like am getting the Name in person property.
Dastagiri Reddy
