Virtusa
Last activity: 18 Jun 2018 19:34 EDT
Tickets and pxFlow
Hi ,
When case moves from stage 1 to stage 2 , pxFlow from stage 1 gets deleted , and ticket cannot be used in stage 2 , is there any way to prevent that pxFlow getting deleted ?
P.S : just an approach using tickets, instead of using Change Stage utility
Likes (8)
AKHIL prudhvi Preethi G saroj kawte vijeta deshpande Pratik agarwal and 3 More -
Once the flow is finished, the pxFlow page will be removed. What is the reason for not wanting to use the Change Stage option?
Virtusa
You could use the StartFlow activity if you want to re-start the flow.
Virtusa
Thanks , I will try that , What is the difference between StartFlow and StartNewFlow activity ?
Startnewflow -Starts an additional flow execution on the current work item.
Startflow -The standard Start a New Flow on the Object (StartFlow ) activity checks if each of the flow's required parameters are present, as well as run the flow catching all exceptions.
Arun
Virtusa
Thanks , Would you be able to provide a use case when StartFlow and StartNewFlow would be used ?
Virtusa
Any help is much appreciated , Thanks
