express script
express script
express script
Posted: May 11, 2018
Last activity: May 28, 2018
Last activity: 28 May 2018 3:45 EDT
IE 11 crash (Pega 7.2.2 upgrade)
In Production ,When we select multiple images System crashes .
ERROR MESSAGES:
Show More
ERROR MESSAGES:
# A fatal error has been detected by the Java Runtime Environment:
# EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x21d139fb, pid=5196, tid=9572
# JRE version: 6.0_45-b06
# Java VM: Java HotSpot(TM) Client VM (20.45-b01 mixed mode, sharing windows-x86 )
# Problematic frame:
# C 0x21d139fb
# If you would like to submit a bug report, please visit:
# The crash happened outside the Java Virtual Machine in native code.
# See problematic frame for where to report the bug.
--------------- T H R E A D ---------------
Current thread (0x073adc00): JavaThread "main" [_thread_in_native, id=9572, stack(0x04d60000,0x04f60000)]
siginfo: ExceptionCode=0xc0000005, reading address 0x00000014
Registers:
EAX=0x42022ea0, EBX=0x00000800, ECX=0x00000000, EDX=0x04f5c128
ESP=0x04f5c09c, EBP=0x04f5c108, ESI=0x073add28, EDI=0x80004005
EIP=0x21d139fb, EFLAGS=0x00210246
Top of Stack: (sp=0x04f5c09c)
0x04f5c09c: 42022ea0 21d215bc 04f5c128 00000001
0x04f5c0ac: 00000800 04f5c110 073adc00 3447c6d8
0x04f5c0bc: 3447c6d8 00000000 073adc00 04f5c0e4
0x04f5c0cc: 2268f2d6 073ae4d4 00000000 00000001
0x04f5c0dc: 073adc00 073adc00 04f5c118 2267dc7d
0x04f5c0ec: 00000000 04f5c10c 2266465c 00000001
0x04f5c0fc: 32803850 22664664 00000000 04f5c168
0x04f5c10c: 228b9fc7 073add28 04f5c1a4 0e4513c0
Instructions: (pc=0x21d139fb)
0x21d139db: 40 00 80 bb 00 08 00 00 75 1b 8b 45 18 8b 08 8d
0x21d139eb: 55 08 52 53 6a 01 8d 55 20 52 68 bc 15 d2 21 50
0x21d139fb: ff 51 14 eb 3e 83 7d 24 04 75 3a 8b 45 18 8b 08
0x21d13a0b: 8d 55 fc 52 68 ec 15 d2 21 50 ff 11 85 c0 7d 11
Register to memory mapping:
EAX=0x42022ea0 is an unknown value
EBX=0x00000800 is an unknown value
ECX=0x00000000 is an unknown value
EDX=0x04f5c128 is pointing into the stack for thread: 0x073adc00
ESP=0x04f5c09c is pointing into the stack for thread: 0x073adc00
EBP=0x04f5c108 is pointing into the stack for thread: 0x073adc00
ESI=0x073add28 is an unknown value
EDI=0x80004005 is an unknown value
Stack: [0x04d60000,0x04f60000], sp=0x04f5c09c, free space=2032k
Native frames: (J=compiled Java code, j=interpreted, Vv=VM code, C=native code)
C 0x21d139fb Java_sun_plugin2_main_server_IExplorerPlugin_iDispatchInvoke0+0x48
j sun.plugin2.main.server.IExplorerPlugin.iDispatchInvoke0(JJLjava/lang/String;IZJI[Ljava/lang/Object;)I+0
j sun.plugin2.main.server.IExplorerPlugin.iDispatchInvoke(JLjava/lang/String;IJI)Ljava/lang/Object;+22
j sun.plugin2.main.server.IExplorerPlugin.javaScriptCallImpl(Lsun/plugin2/liveconnect/BrowserSideObject;Ljava/lang/String;[Ljava/lang/Object;I)Ljava/lang/Object;+73
J sun.plugin2.main.server.IExplorerPlugin.javaScriptEval(Lsun/plugin2/liveconnect/BrowserSideObject;Ljava/lang/String;)Ljava/lang/Object;
j sun.plugin2.main.server.JVMInstance$3.run()V+11
J sun.plugin2.main.server.IExplorerPlugin$1.run()V
C 0x226fb88b JVM_Clone+0x3b16b
C 0x2278d551 JVM_FindSignal+0x507a1
C 0x226fb90d JVM_Clone+0x3b1ed
C 0x22696301 JNI_GetCreatedJavaVMs+0x4341
C 0x226991cc JNI_GetCreatedJavaVMs+0x720c
C 0x21d1178d Java_sun_plugin2_main_server_WindowsHelper_uninstallHook+0x81
C 0x21d185b3 DllGetClassObject+0x1c4d
C 0x21d17a2b DllGetClassObject+0x10c5
C [user32.DLL+0x162fa] gapfnScSendMessage+0x332
C [user32.DLL+0x16d3a] GetThreadDesktop+0xd7
C [user32.DLL+0x177c4] CharPrevW+0x138
C [user32.DLL+0x1788a] DispatchMessageW+0xf
C [QIPCAP.dll+0x1a348]
C [IEFRAME.dll+0x1aaec] DllCanUnloadNow+0x91cc
C [IEFRAME.dll+0x8f2f8] SetQueryNetSessionCount+0xe08
C [iertutil.dll+0xf30ec] PrivateCoInternetCombineIUri+0x2bbc
C [IEShims.dll+0x3a31] IEShims_SetRedirectRegistryForThread+0x1c1
C [kernel32.dll+0x1343d] BaseThreadInitThunk+0x12
C [ntdll.dll+0x39832] RtlInitializeExceptionChain+0x63
C [ntdll.dll+0x39805] RtlInitializeExceptionChain+0x36
Java frames: (J=compiled Java code, j=interpreted, Vv=VM code)
j sun.plugin2.main.server.AbstractPlugin.showStatus(Ljava/lang/String;)V+44
v ~StubRoutines::call_stub
--------------- P R O C E S S ---------------
Java Threads: ( => current thread )
0x0e44a400 JavaThread "JVM[id=5]-Heartbeat" [_thread_blocked, id=10504, stack(0x44b60000,0x44c60000)]
0x0e44c400 JavaThread "JRE Proprietary information hidden Worker Thread" [_thread_blocked, id=10556, stack(0x44480000,0x44580000)]
0x0e44b800 JavaThread "JRE Proprietary information hidden Output Reader Thread" [_thread_in_native, id=11044, stack(0x42260000,0x42360000)]
0x0e44b000 JavaThread "JRE Proprietary information hidden Output Reader Thread" [_thread_in_native, id=3208, stack(0x44360000,0x44460000)]
0x0e449c00 JavaThread "Thread-10" [_thread_in_native, id=2180, stack(0x44250000,0x44350000)]
0x0e449800 JavaThread "Java Plug-In Pipe Worker Thread (Server-Side)" daemon [_thread_in_native, id=9840, stack(0x440c0000,0x441c0000)]
0x255bac00 JavaThread "traceMsgQueueThread" daemon [_thread_blocked, id=1940, stack(0x25830000,0x25930000)]
0x0e42e000 JavaThread "Low Memory Detector" daemon [_thread_blocked, id=3440, stack(0x25390000,0x25490000)]
0x0e41a000 JavaThread "C1 CompilerThread0" daemon [_thread_blocked, id=7212, stack(0x251b0000,0x252b0000)]
0x0e419000 JavaThread "Attach Listener" daemon [_thread_blocked, id=10880, stack(0x25050000,0x25150000)]
0x0e416000 JavaThread "Signal Dispatcher" daemon [_thread_blocked, id=4452, stack(0x24f50000,0x25050000)]
0x0e40a000 JavaThread "Finalizer" daemon [_thread_blocked, id=11228, stack(0x24df0000,0x24ef0000)]
0x0e408c00 JavaThread "Reference Handler" daemon [_thread_blocked, id=8532, stack(0x24c10000,0x24d10000)]
=>0x073adc00 JavaThread "main" [_thread_in_native, id=9572, stack(0x04d60000,0x04f60000)]
Other Threads:
0x0e3cb400 VMThread [stack: 0x24980000,0x24a80000] [id=11248]
0x0e447c00 WatcherThread [stack: 0x254b0000,0x255b0000] [id=9688]
VM state:not at safepoint (normal execution)
VM Mutex/Monitor currently owned by a thread: None
Heap
def new generation total 4928K, used 4029K [0x32470000, 0x329c0000, 0x32f10000)
eden space 4416K, 86% used [0x32470000, 0x3282ee28, 0x328c0000)
from space 512K, 37% used [0x32940000, 0x32970988, 0x329c0000)
to space 512K, 0% used [0x328c0000, 0x328c0000, 0x32940000)
tenured generation total 10944K, used 546K [0x32f10000, 0x339c0000, 0x34470000)
the space 10944K, 4% used [0x32f10000, 0x32f98a08, 0x32f98c00, 0x339c0000)
compacting perm gen total 12288K, used 1132K [0x34470000, 0x35070000, 0x38470000)
the space 12288K, 9% used [0x34470000, 0x3458b0b8, 0x3458b200, 0x35070000)
ro space 10240K, 51% used [0x38470000, 0x389a3000, 0x389a3000, 0x38e70000)
rw space 12288K, 55% used [0x38e70000, 0x3950e4f8, 0x3950e600, 0x39a70000)
Code Cache [0x228b0000, 0x22970000, 0x248b0000)
total_blobs=350 nmethods=194 adapters=92 free_code_cache=32772864 largest_free_block=0
Dynamic libraries:
0x001b0000 - 0x00278000 C:\Program Files (x86)\Internet Explorer\IEXPLORE.EXE
0x77db0000 - 0x77f30000 C:\WINDOWS\SysWOW64\ntdll.dll
0x75770000 - 0x75880000 C:\WINDOWS\syswow64\kernel32.dll
0x75cb0000 - 0x75cf7000 C:\WINDOWS\syswow64\KERNELBASE.dll
0x74410000 - 0x7448b000 C:\WINDOWS\SysWOW64\SYSFER.DLL
0x75d20000 - 0x75dc1000 C:\WINDOWS\syswow64\ADVAPI32.dll
0x77920000 - 0x779cc000 C:\WINDOWS\syswow64\msvcrt.dll
0x76e10000 - 0x76e29000 C:\WINDOWS\SysWOW64\sechost.dll
0x777a0000 - 0x77890000 C:\WINDOWS\syswow64\RPCRT4.dll
0x75660000 - 0x756c0000 C:\WINDOWS\syswow64\SspiCli.dll
0x75650000 - 0x7565c000 C:\WINDOWS\syswow64\CRYPTBASE.dll
0x73520000 - 0x737c7000 C:\ProgramData\Symantec\Symantec Endpoint Protection\14.0.2422.0202.105\Data\Definitions\IPSDefs\20180427.061\IPSEng32.dll
0x75d10000 - 0x75d15000 C:\WINDOWS\syswow64\PSAPI.DLL
0x75890000 - 0x75895000 C:\WINDOWS\syswow64\api-ms-win-downlevel-advapi32-l1-1-0.dll
0x75f20000 - 0x76156000 C:\WINDOWS\syswow64\iertutil.dll
0x75880000 - 0x75884000 C:\WINDOWS\syswow64\api-ms-win-downlevel-version-l1-1-0.dll
0x74bd0000 - 0x74bd9000 C:\WINDOWS\system32\version.DLL
0x75ca0000 - 0x75ca4000 C:\WINDOWS\syswow64\api-ms-win-downlevel-user32-l1-1-0.dll
0x75980000 - 0x75a80000 C:\WINDOWS\syswow64\user32.DLL
0x75b00000 - 0x75b90000 C:\WINDOWS\syswow64\GDI32.dll
0x75a80000 - 0x75a8a000 C:\WINDOWS\syswow64\LPK.dll
0x774c0000 - 0x7755d000 C:\WINDOWS\syswow64\USP10.dll
0x75970000 - 0x75973000 C:\WINDOWS\syswow64\api-ms-win-downlevel-normaliz-l1-1-0.dll
0x770a0000 - 0x770a3000 C:\WINDOWS\syswow64\normaliz.DLL
0x75d00000 - 0x75d04000 C:\WINDOWS\syswow64\api-ms-win-downlevel-shlwapi-l1-1-0.dll
0x75aa0000 - 0x75af7000 C:\WINDOWS\syswow64\shlwapi.DLL
0x73360000 - 0x73363000 C:\WINDOWS\system32\api-ms-win-core-synch-l1-2-0.DLL
0x76e30000 - 0x76e90000 C:\WINDOWS\system32\IMM32.DLL
0x758a0000 - 0x7596d000 C:\WINDOWS\syswow64\MSCTF.dll
0x74c10000 - 0x74c27000 C:\WINDOWS\SysWOW64\BTPLOA~1.DLL
0x74be0000 - 0x74c06000 C:\WINDOWS\system32\privman32.dll
0x76160000 - 0x76dac000 C:\WINDOWS\syswow64\SHELL32.dll
0x756c0000 - 0x756d9000 C:\WINDOWS\syswow64\USERENV.dll
0x75a90000 - 0x75a9b000 C:\WINDOWS\syswow64\profapi.dll
0x00670000 - 0x006b2000 C:\WINDOWS\SysWOW64\QIPCAP.dll
0x74260000 - 0x742a4000 C:\WINDOWS\system32\DNSAPI.dll
0x75ba0000 - 0x75bd5000 C:\WINDOWS\syswow64\WS2_32.dll
0x77090000 - 0x77096000 C:\WINDOWS\syswow64\NSI.dll
0x59710000 - 0x59714000 C:\WINDOWS\system32\api-ms-win-downlevel-shell32-l1-1-0.dll
0x0fae0000 - 0x107f2000 C:\WINDOWS\system32\IEFRAME.dll
0x76e90000 - 0x76fed000 C:\WINDOWS\syswow64\ole32.dll
0x76ff0000 - 0x77081000 C:\WINDOWS\syswow64\OLEAUT32.dll
0x70ad0000 - 0x70c6e000 C:\WINDOWS\WinSxS\x86_microsoft.windows.common-controls_6595b64144ccf1df_6.0.7601.23403_none_2b180b30457f196c\comctl32.dll
0x68c80000 - 0x68ccb000 C:\Program Files (x86)\Internet Explorer\IEShims.dll
0x77580000 - 0x775fb000 C:\WINDOWS\syswow64\comdlg32.dll
0x75b90000 - 0x75b94000 C:\WINDOWS\syswow64\api-ms-win-downlevel-ole32-l1-1-0.dll
0x6f9c0000 - 0x6fa40000 C:\WINDOWS\system32\uxtheme.dll
0x771e0000 - 0x7748b000 C:\WINDOWS\syswow64\WININET.dll
0x74600000 - 0x74608000 C:\WINDOWS\system32\Secur32.dll
0x6d1e0000 - 0x6d1e4000 C:\WINDOWS\system32\api-ms-win-downlevel-advapi32-l2-1-0.dll
0x75dd0000 - 0x75f1b000 C:\WINDOWS\syswow64\urlmon.dll
0x74300000 - 0x7433c000 C:\WINDOWS\system32\mswsock.dll
0x742f0000 - 0x742f6000 C:\WINDOWS\System32\wship6.dll
0x74c40000 - 0x74c5c000 C:\WINDOWS\system32\IPHLPAPI.DLL
0x74c30000 - 0x74c37000 C:\WINDOWS\system32\WINNSI.DLL
0x73840000 - 0x73857000 C:\WINDOWS\system32\CRYPTSP.dll
0x73800000 - 0x7383b000 C:\WINDOWS\system32\rsaenh.dll
0x73150000 - 0x7315e000 C:\WINDOWS\system32\RpcRtRemote.dll
0x77890000 - 0x77913000 C:\WINDOWS\syswow64\CLBCatQ.DLL
0x68c30000 - 0x68c7a000 C:\Program Files (x86)\Internet Explorer\ieproxy.dll
0x6e910000 - 0x6e914000 C:\WINDOWS\system32\api-ms-win-downlevel-shlwapi-l2-1-0.dll
0x74f50000 - 0x74f63000 C:\WINDOWS\system32\dwmapi.dll
0x500d0000 - 0x51533000 C:\WINDOWS\system32\MSHTML.dll
0x69430000 - 0x69777000 C:\WINDOWS\system32\d2d1.dll
0x69780000 - 0x698b6000 C:\WINDOWS\system32\DWrite.dll
0x6d7d0000 - 0x6d81c000 C:\WINDOWS\system32\dxgi.dll
0x72d60000 - 0x72d77000 C:\WINDOWS\system32\bcrypt.dll
0x70ed0000 - 0x70f0d000 C:\WINDOWS\SysWOW64\bcryptprimitives.dll
0x75be0000 - 0x75c0f000 C:\WINDOWS\syswow64\WINTRUST.dll
0x770b0000 - 0x771d2000 C:\WINDOWS\syswow64\CRYPT32.dll
0x76e00000 - 0x76e0c000 C:\WINDOWS\syswow64\MSASN1.dll
0x68380000 - 0x684f5000 C:\WINDOWS\system32\d3d11.dll
0x5a4f0000 - 0x5b5af000 C:\WINDOWS\system32\igd10iumd32.dll
0x70f10000 - 0x70f49000 C:\WINDOWS\system32\ncrypt.dll
0x51720000 - 0x525fe000 C:\WINDOWS\system32\igc32.dll
0x74b80000 - 0x74bcc000 C:\WINDOWS\system32\apphelp.dll
0x68b60000 - 0x68ba3000 C:\Program Files (x86)\WebEx\Productivity Tools\ptonecli.dll
0x67cb0000 - 0x67d21000 C:\Program Files (x86)\WebEx\Productivity Tools\MSVCP120.dll
0x67bc0000 - 0x67cae000 C:\Program Files (x86)\WebEx\Productivity Tools\MSVCR120.dll
0x73c20000 - 0x73c2d000 C:\WINDOWS\system32\WTSAPI32.dll
0x68ad0000 - 0x68b56000 C:\Program Files (x86)\WebEx\Productivity Tools\ptonres.DLL
0x6d880000 - 0x6d88b000 C:\Program Files (x86)\WebEx\Productivity Tools\wbxtrace.dll
0x67d60000 - 0x67de4000 C:\WINDOWS\WinSxS\x86_microsoft.windows.common-controls_6595b64144ccf1df_5.82.7601.18837_none_ec86b8d6858ec0bc\comctl32.dll
0x77f30000 - 0x77f37000 C:\WINDOWS\system32\msiltcfg.dll
0x6ed00000 - 0x6ef46000 C:\WINDOWS\system32\msi.dll
0x68a60000 - 0x68ac3000 C:\WINDOWS\SysWOW64\pmbho.dll
0x745c0000 - 0x745d1000 C:\WINDOWS\SysWOW64\NETAPI32.dll
0x745b0000 - 0x745b9000 C:\WINDOWS\SysWOW64\netutils.dll
0x74590000 - 0x745a9000 C:\WINDOWS\SysWOW64\srvcli.dll
0x74580000 - 0x7458f000 C:\WINDOWS\SysWOW64\wkscli.dll
0x68a20000 - 0x68a57000 C:\Program Files (x86)\Microsoft Office\Office15\OCHelper.dll
0x6c520000 - 0x6c589000 C:\WINDOWS\system32\MSVCP100.dll
0x6a6b0000 - 0x6a76f000 C:\WINDOWS\system32\MSVCR100.dll
0x68a10000 - 0x68a13000 C:\Program Files (x86)\Microsoft Office\Office15\1033\OcHelperResource.dll
0x04f60000 - 0x04fb7000 C:\Program Files (x86)\Java\jre6\bin\ssv.dll
0x04fc0000 - 0x05016000 C:\Program Files (x86)\Java\jre6\bin\MSVCR71.dll
0x0f580000 - 0x0f611000 C:\PROGRA~2\MICROS~1\Office14\URLREDIR.DLL
0x74360000 - 0x74403000 C:\WINDOWS\WinSxS\x86_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.6161_none_50934f2ebcb7eb57\MSVCR90.dll
0x53a40000 - 0x53a55000 C:\PROGRA~2\MICROS~1\Office14\MSOHEV.DLL
0x06c30000 - 0x06c3d000 C:\Program Files (x86)\Java\jre6\bin\jp2ssv.dll
0x6c2e0000 - 0x6c33f000 C:\WINDOWS\system32\SXS.DLL
0x68bb0000 - 0x68c28000 C:\WINDOWS\system32\IEUI.dll
0x73be0000 - 0x73be5000 C:\WINDOWS\System32\wshtcpip.dll
0x73ab0000 - 0x73ab6000 C:\WINDOWS\system32\rasadhlp.dll
0x73ac0000 - 0x73af8000 C:\WINDOWS\System32\fwpuclnt.dll
0x75020000 - 0x75028000 C:\WINDOWS\system32\credssp.dll
0x6e920000 - 0x6e961000 C:\WINDOWS\SysWOW64\schannel.dll
0x6e8f0000 - 0x6e906000 C:\WINDOWS\system32\GPAPI.dll
0x6e8d0000 - 0x6e8ed000 C:\WINDOWS\system32\cryptnet.dll
0x76db0000 - 0x76df5000 C:\WINDOWS\syswow64\WLDAP32.dll
0x69310000 - 0x69316000 C:\WINDOWS\system32\SensApi.dll
0x58940000 - 0x5896e000 C:\WINDOWS\system32\mlang.dll
0x68120000 - 0x681ac000 C:\Windows\SysWOW64\uiautomationcore.dll
0x72ee0000 - 0x72f1c000 C:\Windows\SysWOW64\OLEACC.dll
0x090a0000 - 0x094f3000 C:\windows\SysWOW64\jscript9.dll
0x68a00000 - 0x68a0b000 C:\WINDOWS\system32\msimtf.dll
0x69330000 - 0x69425000 C:\WINDOWS\system32\PROPSYS.dll
0x70c70000 - 0x70c9f000 C:\WINDOWS\system32\XmlLite.dll
0x72d80000 - 0x72eb4000 C:\WINDOWS\System32\msxml3.dll
0x58730000 - 0x58861000 C:\WINDOWS\system32\windowscodecs.dll
0x69090000 - 0x6909c000 C:\WINDOWS\system32\ImgUtil.dll
0x77600000 - 0x7779d000 C:\WINDOWS\syswow64\SETUPAPI.dll
0x77490000 - 0x774b7000 C:\WINDOWS\syswow64\CFGMGR32.dll
0x77560000 - 0x77572000 C:\WINDOWS\syswow64\DEVOBJ.dll
0x73280000 - 0x732a1000 C:\WINDOWS\system32\ntmarta.dll
0x58af0000 - 0x58c47000 C:\WINDOWS\System32\msxml6.dll
0x74760000 - 0x74792000 C:\WINDOWS\system32\WINMM.dll
0x04540000 - 0x0454c000 C:\Program Files (x86)\Common Files\Microsoft Shared\OFFICE15\MSOXMLMF.DLL
VM Arguments:
jvm_args: -Xbootclasspath/a:C:\PROGRA~2\Java\jre6\lib\deploy.jar;C:\PROGRA~2\Java\jre6\lib\javaws.jar;C:\PROGRA~2\Java\jre6\lib\plugin.jar -Xmx32m -Djava.awt.headless=true -Dkernel.background.download=false -Dkernel.download.dialog=false -XX:MaxDirectMemorySize=64m
java_command: <unknown>
Launcher Type: generic
Environment Variables:
PATH=C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\Program Files (x86)\WebEx\Productivity Tools;C:\Program Files\Internet Explorer;
USERNAME=ricnl6
OS=Windows_NT
PROCESSOR_IDENTIFIER=Intel64 Family 6 Model 94 Stepping 3, GenuineIntel
--------------- S Y S T E M ---------------
OS: Windows 7 , 64 bit Build 7601 Service Pack 1
CPU:total 8 (4 cores per cpu, 2 threads per core) family 6 model 94 stepping 3, cmov, cx8, fxsr, mmx, sse, sse2, sse3, ssse3, sse4.1, sse4.2, popcnt, ht
Memory: 4k page, physical 16662264k(11929020k free), swap 33322652k(28104424k free)
vm_info: Java HotSpot(TM) Client VM (20.45-b01) for windows-x86 JRE (1.6.0_45-b06), built on Mar 26 2013 13:40:03 by "java_re" with MS VC++ 7.1 (VS2003)
time: Mon Apr 30 11:25:34 2018
elapsed time: 5979 seconds
Show Less
