Accenture
Last activity: 2 May 2018 5:40 EDT
Run on Client with Refresh When on Property changes Not working
We have 2 sections A and Section B, Section A has the dropdown (Say with property name " Type") with on change with Refresh Section/Activity call. And Section B should also refresh when ever dropdown in Section A changes. This was implemented by checking Run on Client checkbox and Refresh when condition saying Property changes(property present in Section A with dropdown).
What is happening is, when ever the dropdown value changes in Section A, in the background it is refreshing Section B as well. But dropdown value is lost in between the reload and causing the error.
Is there any configuration(environment specific etc) needed to make it work with Run on client. Also, this behavior is happening in only one of the environment, all other environments it works perfect.
