    Infosys
Last activity: 24 May 2017 1:11 EDT
Run on client functionality is not working as expected.
Hi, I am facing a issue while keeping run on client condition for a dynamic layouts visible when expression.
Steps:
1. Configure two dynamic layouts in a section.
2. Open this section using a Modal Window.
3. Change is the value of a property referenced in Dynamic layout1, should change the visibility of Dynamic layout2 if we have configure Visible when expression for dynamic layout2 keeping run on client enabled.
Expected:
It should show me some change in the visibility of dynamic layout2 on change of property referenced in dynamic layout1.
Actual:
There is no change in the visibility of dynamic layout2 on change of property referenced in dynamic layout1.
But if we don't use modal Window for opening the section referencing both the dynamic layouts, the same condition works as expected. Is there any constraint on run on client functionality that its not compatible with modal Window ?
