Services Australia
Last activity: 26 Apr 2018 15:20 EDT
Non Prod Database Consolidation
We are planning to perform Database consolidation by allocating only one database instance for all NON-prod environments and rename the schema's based on the environments.
For example, (PEGA_RULES_DEV, PEGA_DATA_DEV) (PEGA_RULES_SIT, PEGA_DATA_SIT), (PEGA_RULES_UAT, PEGA_DATA_UAT), (PEGA_RULES_PREPROD, PEGA_DATA_PREPROD).
Please advise us whether this is feasible? Would there be any concerns? What are the configuration changes required for this approach. Has anyone tried this before?
Yes, this is feasible. If you considered the database server size and the processing speed. As all NON-PROD env's are in single database, I would recommend involve the DBA.
Coming to the Database rule type configuration for the respective PEGA environment. For example, you are configuring using the JDBC URL, need to configure something like below
jdbc:oracle:thin:@//DATABASE_SERVER_NAME:PORT_NUMBER/SCHEMA_NAME
Sandeep P V
